<!--QuoteBegin-eliepower+07.10.2005 à 19:11--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>
QUOTE (eliepower @ 07.10.2005 à 19:11)</td></tr><tr><td id='QUOTE'><!--QuoteEBegin--> Olive BDR, It seems that there is a lot you don't understand but one thing i can say, buy specialist parts at a specialist even if they seem to be more expencive. In the UK there are people ho are highly specialized in the busines the do and mostly they only deal in 2 or 3 items. This means that someone ho tunes Ford engines knows them inside out but don't ask any thing about a different make of engine because he will not be able to help you.
First of all : the 4th gear is always a direct drive ( prise direct ) so even on a SC box this makes no whing noise.
The long or short imput shaft relates to the part witch goes into the cranckshaft : long is for Ford and VX short for ehhh .... the other engine <!--QuoteEnd--> </td></tr></table><div class='postcolor'> <!--QuoteEEnd-->
Merci Elie pour ces précisions.
Je vais suivre tes conseils d'autant plus que burton a déjà fait ses preuves en ce qui concerne leur réticence à donner des conseils lors de mon changement de joint de culasse.
Je vois donc m'adresser à Bgh ou à Spc.
Spc si je choisis des pignons smi jélicoidaux
Bgh si je choisis la même soluce que dreamcat...
<!--emo&
topic croisés à conserver dans les favoris !!! <!--emo&
<!--emo&
<img src='http://img234.echo.cx/img234/8810/logopetitfrench5or.jpg' border='0' alt='user posted image' />
<span style='font-size:8pt;line-height:100%'><i>c'est le pied quoi...</i></span>
