Tirant De Pont Avec Uniball
#16
Catherman, no there are no new toys or enything else. <!--emo&Cry-->[img]http://www.forum-autoroule.com/html/emoticons/icon_cry.gif' border='0' style='vertical-align:middle' alt='icon_cry.gif' /><!--endemo-->
The watts linkage is some thing to disguise a flaw in the DD set up, you must know that a DD is a further developt for heavy saloons just arround the sec. war. When people want more confort and more speed out of the heavy axle arrangement those heavey saloons had. It is a mix between a live axle and indep. suspension.
I still believe that a live axle with 5 link set-up is the best for a Seven, only you need to find an axle that is light and strong enough to cope with the power, a all ali housing with ford banjo internals would be perfect, you would be able to run it on soft springs ( for comfort ) and still have plenty of traction.
Elie,
Wouldn t you consider an IRS set up as more practical at the end of the day? I understand the benefit of a DD or LA set up on a flat tarmac for tractability, however in real life a proper IRS might be a better engineering solution?
Darkvador, The IRS would be the best solution, however a Seven is all about simplicity and if you have a look at the new chassis that's gone a long way off.
To keep things in the family i would opt for the Chapman strut, this would lead to little or no modification to the chassis.
Since the roads these days are much better than say 20-30 years ago the disadvantages from a live axle are far more less than in those days, all depending on the type of springs you have.
<!--QuoteBegin-huggy+30.12.2005 à 21:49--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (huggy @ 30.12.2005 à 21:49)</td></tr><tr><td id='QUOTE'><!--QuoteEBegin--> Pour revenir au post original:
Les barres deWatts sont celles situé à l'arrière du pont: On est d'accord ?
Mais l'idée était eventuellement de ne monter que les barres "AV" que toutes les de dion ont mais sur uniball.
L'ensemble des 4 barres est le système watts linkage.
Les barres avant ne peuvent être montées seules car elles sont receptionnées par une bielette spéciales...
Si tu veux faire cette modif voilà comment je ferais:
Je commanderais deux bras normaux.
Je trouverais les uniballs repondant à mon problème c'est à dire facilité de montage sur la barre d'origiene et diamêtre du boulon de fixation du Dedion a récupérer...
Pour adapter l'uniball, je couperais le bras en extrémité de tube et j'y souderais le filetage femelle correspondant à l'uniball choisie...
SV Road Sport 200 9500 kms
RPP 338... en hausse
http://clefde7.free.fr
L unibal permet de limiter les jeux. A mon a vis, il n y a pas d interet a monter les bras avant (radius arms) sur unibal alors que tu n as pas de barres arrieres.
La rigidité ainsi gagnée est marginale par rapport au systeme dedion
